Replacing your TELUS Secure Business Door & Window Sensor
Instructions on how to replace your Door & Window Sensor.
How to swap your TELUS Secure Business Door and Window Sensors
Remove the old magnet and sensor from their surfaces. Be careful as the adhesive may be strong. An adhesive remover and putty knife may provide a cleaner removal.
Ensure the surfaces are completely dry before installing the new magnet and sensor.
