Adding an automation device through my Control Panel
Instructions to add an automation device using the Control Panel instead of the TELUS SmartHome app
If you are unable to add an automation device through your TELUS SmartHome app, you can try adding it through your Control Panel instead by following these simple steps here.
Yes
No
Related articles
To remove an automation device from your TELUS SmartHome Security system, follow these instructions here
