Skip to contentSkip to search
Troubleshoot problems with your phone battery
Tips for extending the charge on your device's battery
Many factors can drain a device's battery. The applications used, the environment, the way a device is charged, and the device settings all impact your device's battery performance. Below are some tips to help your battery last longer.
Yes
No
Related articles
Tips and warranty information for phones, tablets, mobile internet devices, smart hubs and watch devices.
Costs and eligibility for TELUS Device Care
What to do when your device is no longer supported for repair
Get real-time tips to improve, repair and determine the value of your device with the app.
Solve issues you may experience with TELUS Track+
