Skip to contentSkip to search
Optimize your Smart Hub experience
Follow these steps to ensure you have the most optimal experience with your Smart Hub.
Minimize radio interference
Some devices may cause interference with your Wi-Fi signal if they are within close proximity (8-10 feet) of your Smart Hub. If possible, try removing or turning off the sources of potential interference. Try to relocate the following away from your Smart Hub and Wi-Fi devices:
  • Cordless telephone base station
  • Other wireless modems or routers
  • Dense or metallic objects (file cabinets, brick walls, etc.)
  • Copper or other metallic pipes
  • Appliances, such as microwave ovens, air conditioners and television sets
  • Garage door openers
  • Building materials
  • Bluetooth devices
  • Wireless speaker system
  • Baby monitors
  • Wireless security cameras
  • Certain monitors and LCD displays
Yes
No
Related articles
Step-by-step guide and FAQ to help you install your TELUS Smart Hub internet service.
These quick start guides will help you get started with your Smart Hub.
