| | Please check the power source. |
| | Your camera is ready and connected to your TELUS SmartHome Security System. |
| | Camera is connected to the network but not to the internet. If this happens, here are some tips to troubleshoot: |
Your camera is restoring to factory default settings. To perform a factory reset, press and hold the WPS button for about 10-15 seconds. |
| Power on or no local or internet connection | The camera is powering on, this takes between 60-90 seconds. If longer than 90 seconds, the camera is not connected to the internet. |
| | Please wait, the camera is powering on or a firmware upgrade is in progress. |
| | Your camera is ready to connect to the Wi-Fi network. |
